How do I capture the quadrature encoder Z-index pulse using 6035E DAQ card?
Currently, I'm using 6035E to measure the angular position of servo motor.
I'm able to read the counts from Channel A and Channel B.
From the technical note which I downloaded from this website, I understand that the Ch A and Ch B should be connected to pin 37(PFI8/CTR0 SRC) and pin 16(P0.6) of I/O connector, respectively.
However, it doesn't indicate any solution of capturing the Z-index pulse.
I'm wondering whether I can read the pulse by connecting to pin 3 (PFI9/CTR0 GATE).
In fact, I have tried it out and it worked. I can see the counter is counting from the MAX.
The problem is I don't know which VI I suppose to use.
I don't know how to program it in LabVIEW.
If this is not the right, what are the alternatives?
Please enlighten me. Thanks.
IANES
(3,851 Views)
Hey IANES,
I am assuming you are using LabVIEW 7.1 and the most recent NI-DAQ driver 7.3.1 or so. Also I am going to assume that you are using the DAQmx VI's. You need to select the "Create Channel.VI", and then left click underneath of it and choose the following: Counter Input -> Position -> and then the type of Encoder that you are using. Then you also need to use the DAQmx Timing.VI and the DAQmx Read.VI to do what you want. Take a look at the Example Programs that you can access by using the Help -> Find Examples, and search for the Examples that use counters. Also, I have attached a small VI with the Create Channel.VI in it with the Z-Index options set up for it. Hope this helps. Good luck with your application.
DJ Loberg
(3,838 Views)
Thank you for your helping.
In fact, I've tried it out before. However, it seems like the device doesn't support the VI you suggested.
I dumped the DAQ assistant.VI into the block diagram and select the desired type of encoder. The message under the Supported Physical Channel is 'No supported devices found'.
If I run the program, the pop-up window is shown (Pic[3]).
Is it the problem can be solved?
Please find the attached files.
Thanks.
IANES
(3,827 Views)
One more thing is you didn't mention which I/O connector pin supposed to connect the Z-index pulse?
Or it is not necessary of the connection. It's purely done by the program?
Thanks.
IANES
(3,827 Views)
E Series Devices don't really support the Z index of quadrature encoders by default. That is why you are getting the error in DAQmx. Normally, to do a quadrature encoder measurement you would want to use a TIO device or a new M series board. I found the following article on the NI website which describes how you might use an E series device and some of the limitations. There also were a few other articles which seemed to have info that you might want to search for.
http://zone.ni.com/devzone/devzoneweb.nsf/Opendoc?openagent&36BD71244BB26FC886256869005E541B
StuartG
(3,818 Views)
