How do I change Hex String to Decimal number?
FWIW, you can remove the 1st typecast entirely and just wire the string from the string subset VI to the second typecast-to-DBL.
And as far as the problem you mentioned, I have not seen anything like it unless you want to also consider the state of the operator.
Some of us just work better in the morning.
Message 11 of 11
(551 Views)
