How do I change my printer settings programmatically ?
How do I open a print menu, to change the printer, the orientation and the number of pages to be printed out during the execution of a LabVIEW program ?
(5,134 Views)
Check out the example at:
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3DFC656A4E034080020E74861&p_node=DZ52084&p_submitted=N&p_rank=&p_answer=&p_source=External
If you set the VI to display the printer dialog you can set the printer and the print orientation from there...the number of pages should be possible to control from what you actually put in the VI to be printed.
(5,134 Views)
Thanks for your reply. Unfortunately, I am not able to open the example file. And how can I set the VI to display the Windows printer dialog box? And maybe the number of pages is the wrong word, I meant number of copies. Thanks,
Bart.
(5,134 Views)
Not able to download, decompress, open vi..or?
What version of LabVIEW do you have?
I downloaded and tested the example for LV6:
ftp://ftp.ni.com/contrib/epd/B45EACE3DFC556A4E034080020E74861/LV6defprinter.ZIP
That vi has a boolena input that if set to true will display the print dialog.
(5,134 Views)
Here is another example program you might find useful. It is entitled, "Display Windows Print Setup Dialog".
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3DD2556A4E034080020E74861&p_node=DZ52084&p_submitted=N&p_rank=&p_answer=&p_source=External
It requires LabVIEW 5.0.1
(5,134 Views)
Hi, Jeremy Braden
Is there an example for version LabVIEW 2010?
(4,430 Views)
