How do I change the background color of Controls?
 Attached picture displays the error message. How do I modify this issue?
Thank you for your reply.
KC
Message 1 of 8
(6,581 Views)
you are using controls from the 'system' palette and the appearance of these colors are defined by the operating system of your computer .
If you want to change the color of controls, you have to use controls from the 'modern' or 'classic' palette.
Hope this helps.
Uli
Message 2 of 8
(6,573 Views)
Thanks for Uli' reply.
Attached is the Main Screen.
For pointer slider and spin control controls, it looks nice on the main screen, but I cannot find the same pointer slide and spin control from the 'modern' or 'classic' palette.
Have any method to change the background color of system controls?
Thanks.
KC
Message 3 of 8
(6,540 Views)
Message 4 of 8
(6,531 Views)
Thanks for your reply.
KC
Message 5 of 8
(6,529 Views)
I want to get the appearance of control as attached when Enabled State is on Disabled & grayed, but I cannot find the property of control is Enabled State as attached using property node.
How do I implement this?
KC
Message 6 of 8
(6,484 Views)
Hello KC,
the property is called "Disabled".
0 - Enabled
1- Disabled
2 - Disabled and Grayed Out
Uli
Message 7 of 8
(6,477 Views)
Thank you for Uli' reply.
KC
Message 8 of 8
(6,458 Views)
