How do I change the color map on an Intensity Graph?
I am displaying a grayscale image in an Intensity Graph (internally, the image is just an array of 8-bit pixel values). The Intensity Graph uses a black-blue-white color map to generate the image on-screen. How can I change this color map? The help documentation suggests this can be modified, but I can't find any way on either the front panel or in the block diagram to actually set the color map properties of the Intensity Graph.
Eric Coppock
Ball Aerospace
(4,819 Views)
1/ Disable "interpolate color" (right click on the sacle first ...)
2/ Right click on a scale marker, and select marker color
3/ Enable "interpolate color"
Of course, you can add more markers... and more colors !
CC
Chilly Charly    (aka CC)
(4,813 Views)
Try using the property node set to color table and see if this is what you want
Joe.
"NOTHING IS EVER EASY"
(4,811 Views)
Thanks. Chilly's manual adjustment was just what I needed.
EC
(4,802 Views)
