System exec.vi
When there are DOS .bat and .exe share the same file names, what would System exec.vi tried to do? It seems to execute .exe file over .bat. Anyone tried this?
(3,234 Views)
This is correct. Also if there is a system command ("dir" for example) then a dir.bat will not be executed if the command "dir" is sent.
I think the preferred order is System command > Com > exe > bat, but I'm open to corrections.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,230 Views)
Shane,
My memory confirms what you just posted:
"I think the preferred order is System command > Com > exe > bat".
From what I recall: com > exe > bat
Unless the extention is specified..
So specifying the extention in the System Exec.vi should spawn the appropriate one.
-JLV-
(3,214 Views)
Thanks guys.
The system exec vi has the command line input. I thought I could use this to indicate which file type (dos comd or .exec or .bat..) I am trying to execute...
(3,208 Views)
