How do I change the filename of the .png that is saved when I create an HTML report?
I have a report generation .vi that reads in multiple graphs and appends the "picture" to the .html report. Is it possible to control how LabVIEW names the resultant graph .png?
I'ver attached a picture of the code snipet and the auto generated file.
Thanks!
(2,881 Views)
Could you post your entire VI?
Patrick Corcoran
Application Engineering Specialist | Control
(2,837 Views)
Hi Patrick,
Attached is the .vi.
Thanks!
(2,826 Views)
Accepted by BenMedeiros
The naming convention is designed to ensure no conflicts are generated as this Report Generation Class is called. Below, I have attached a screenshot of the functionality that defines the images names.
You can view this block diagram by double-clicking and opening the report generation tools. While you are free to modify this class to implement a new naming schema, I must insert the disclaimer that this process may have ill-effect on additional functions int he report generation toolkit. As you can see in this code the names are randomly generated, and applied based on a randomized number. You might look into implementing a system that gets the control label from the input control reference, and builds the appropriate file path for the PNG images.
I very much appreciate your time. Please post any additional questions.
Sincerely,
Patrick Corcoran
(2,802 Views)
