How do I change the position of the scale legend on the second y axis of an xy graph?
When I make an XY graph with a second y-axis, the scale legend for this second axis is on the left side of the scale, and on top of the graph! I would like to have the scale legend on the right side of the scale so that it is visible.
(3,011 Views)
I had this experience too in a xy graph with the right axis legend longer than 2 characters (a value of 100.0 is enough for this to happen). Once the legend has moved to the right of the Y axis I found no way to move it to the original position, even reducing the size of the graph plot area or the lenght of the y scale.
I had to use a simple lable instead of the scale label in order to display it correctly. BTW this permitted me put the lable over the Y scale and with special attributes (i.e. size and color), which I cannot obtain with the axis label.
Anyone has some consideration on this?
Roberto
(3,011 Views)
Roberto -
I also have experienced this problem - ever since the ability to have multiple axis plots was introduced. I am currently working with 6.1 and just came across a related problem. When I resize the plot area, (enlarge and then shrink), my "Y" axis labels slowly begin to move off the top of the plot until they are no longer visible. The only way to correct this is to customize the graph and drag the label back down where it belongs. This fix will last for a few "resizes" before you need to go back and do it again. I too am very interested in finding a solution to this problem.
Jim
(3,011 Views)
