How do I change the scroll on the block diagram?
I am trying to find a way to scroll from side to side with the mouse when programming in the block diagram.  I found that if I hold down control and scroll with the mouse wheel while over a case statement it will cycle through the cases.  Scrolling with the mouse wheel with no buttons pressed will allow me to scroll vertically, but how do I scroll horizontally?  Thanks for the help.
(3,744 Views)
If you put the mouse over the horizontal scroll bar at the bottom of the window and scroll it will move horizontally.
Tim Elsey
Certified LabVIEW Architect
(3,743 Views)
Thank you.  Is there a way to do it without going down to the scroll bar?
(3,740 Views)
Accepted by 5thGen
If there is then I don't know it.  I have a mouse with a scroll wheel that clicks left and right, but it doens't work within LabVIEW.
I just found that if you hold ctrl and shift and click and drag on a blank spot you can drag the block diagram around.  That's kinda scrollin
Message Edited by elset191 on 06-04-2009 12:18 PM
Tim Elsey
(3,737 Views)
There's a way to do it without the scroll bar, if you're willing to do it without the mouse wheel.  Holding the Ctrl and Shift keys down switches to the Scrolling (hand) tool and you can drag your BD/FP around.  I use it ALL THE TIME.
Sorry...  I didn't read all the posts.
Message Edited by jcarmody on 06-05-2009 05:09 AM
Jim
(3,701 Views)
Thanks for the tip on how to grab the screen.  That is exactly what I was looking for! Productivity is instantly up 25%.
(3,681 Views)
