How do I change the x-axis to read in log scale?
I go into the properties and go to the scales tab.  Then I change the x-axis to a log scale by checking the box, but the change is never saved.  Does anyone know how to fix this?
Also, I am pretty new at this and I am self taught so I was trying to figure out how to have a real time plot of a dynamic data vs. another dynamic data, how do you achieve this because all the charts are vs time scale and from what I have read graphs are not used for real time plotting.
Rick
(4,085 Views)
 Logarithmic x-scales only work for graphs and not for charts. It should be greyed out for charts, so this is a UI bug.
 Use the xy-graph from the express palette, then configure the "built xy-graph" express node not to clear data between calls.
(4,083 Views)
So I put in the express build xy graph so that I could use log time.  Now nothing comes up when I try to run.  I think this is because I have nothing going into the time.  If I wire the iteration into the express build xy there does not appear any connected data.
(4,080 Views)
Most likely there is a simple fix. Why don't you attach your VI to make it clear what you're doing. 🙂
(4,071 Views)
Here's a very simple draft (LV 8.5) that seems to work just fine. Of course it won't graph the x=0 point, because it can't 😉
Message Edited by altenbach on 11-08-2008 04:26 PM
(4,069 Views)
