How do I combine 2 1-D Arrays?
I realize there are a lot of threads on "combining" arrays, but most want a 2-D array resultant.  I would like a 1-D Array.
Basically, 10 tests are each run, and a waveform graph is produced for each of them.   Then, I take these waveform plots, and combine them in succession.
Ex:
Chart 1:  Data1
Chart 2:  Data2  Data3  Data4
Chart 3:  Data5 Data6
My Desired Outcome:   Data1 Data2 Data3 Data4 Data5 Data6  <~One Dimensional Array
Then make a waveform chart out of that data.
The tricky part is that I cannot use Build Array (Then Reshape Array), since doing that would add 0's to make all waveforms the same length.  One thought I had (that I'd like to avoid) is to simply add an element to "Total Chart" every time an element is added to any of the sub-charts.
Basically, I want the opposite of Split 1-D Array.
Thanks.
Edit: I'm using 8.6
(2,902 Views)
Turn on Context Help (ctrl-h) hover over Build Array,  select Detailed Help from the Help Window and read about Concatenate Inputs.
(2,892 Views)
right click on Build Array and select concatenate inputs
(2,883 Views)
Hey cool, I wish I knew that earlier.
(2,863 Views)
There are lots of little hidden tricks with LabVIEW.  Most of which I do not know of, yet.  And that's what keeps LabVIEW fun,.... the little mysteries. 😉
(2,843 Views)
Surely at least one of those answers has got an Accepted Solution tick written all over it!
LabVIEW 2012
(2,821 Views)
