Is it possible to run Labview ver 6.5 with PowerPC as the target CPU and VxWorks as the target operating system? If Labview ver 6.5 does not support this configuration, do any of the later versions support it?
Is it possible to run Labview version 6.5 with PowerPC as the target CPU and VxWorks as the target operating system?
If version 6.5 does not support this configuration, do any of the later versions support it?
I basically have an Ada executable and Labview executable that currently run on a Sun Machine with Solaris as the operating system.  I'm re-architecting the system hardware and will be getting rid of the Sun Machine and Solaris.  I'm don't have any issues with the Ada executable, but I'm not sure what configurations Labview supports.
(2,429 Views)
