11-15-2006 11:35 AM
11-16-2006
06:23 PM
- last edited on
01-24-2025
04:45 PM
by
Content Cleaner
Hi Sean,
There are a number of ways to connect to your PLC and it all depends on what interfaces your PLC supports. Most customers using Allen-Bradley PLC's use RSLinx OEM to communicate with the PLC. This program contains an OPC server and you can retrieve the data from the OPC server using either LabVIEW's datasocket VI's or the Datalogging and Supervisory Control (DSC) module for LabVIEW.
Connecting LabVIEW to an OPC Server through a DataSocket Connection
If you don't have the Allen-Bradley OPC server you can use our Industrial Automation OPC Server (IA OPC) providing your specific PLC is listed under the supported devices for this OPC server.
NI Industrial Automation OPC Servers
Devices Supported By the IA OPC Server
-Justin D
11-17-2006
08:40 AM
- last edited on
01-24-2025
04:46 PM
by
Content Cleaner
SeanWat wrote:
.... I am looking for any documentation or help with this topic.
There's also Using RSLinx OPC Server which goes into a bit of detail regarding the AB end of things. It is ~5 years old and thus is a bit dated ... but it may help.
11-17-2006 10:25 AM - edited 11-17-2006 10:25 AM
Message Edited by unclebump on 11-17-2006 10:26 AM
12-04-2006
06:36 AM
- last edited on
01-24-2025
04:46 PM
by
Content Cleaner
Donald wrote -
Yes - unfortunately it is outdated. I've posted a spearate query requesting information on the settings for an ethernet connection - not many people will still be using the DF-1 port.
