How do I connect an instrument to my computer; do I need an additional hardware?
I have almost no knowledge of LabVIEW. I just want to know how to connect an instrument to my Microsoft Windows XP based Pentium 4 PC. Is there any hardware intermediate to the PC and the instrument?
(2,517 Views)
It depends on the instrument. some instruments use an interface called GPIB which is also defined by the standard IEE-488. Some instruments connect via a serial connection. Other type of connections are USB and Ethernet. If it's GPIB, then you need a GPIB controller for the PC. First determine the type of remote control interface the instrument has by reading the manual and then you can ask for help in using LabVIEW.
(2,513 Views)
