10-21-2006 03:56 PM
Solved! Go to Solution.
10-23-2006 06:56 PM
EFD,
If you are simply controlling a stepper motor with no feedback or other signals, then the Step and Direction signals will be all you need. The other signal connections on your drive are going to depend on the specific drive itself, so I cannot say specifically what all of them are meant for. Typically, the Ground and Power connections are where you would connect an external power supply. Please let me know if this is helpful.
Chris
