Problem using the Web front end
Hi
I have been playing with the Web publishing tool and  I can get it working fine until I build an executable file.  Then when the vi is loaded using the .exe file the web front end comes up with the comment vi not loaded into memory?
I am obviously doing something wrong but up until now I can not see it?
Any suggestinos welcome.
Cheerrs
Phill
(2,871 Views)
Phill,
Have a look at this KnowledgeBase article:
http://digital.ni.com/public.nsf/websearch/862567530005F09C8025673000529121?OpenDocument
--Paul Mandeltort
Automotive and Industrial Communications Product Marketing
(2,850 Views)
Thanks for the reply.  I was just about to post a reply to my own question with the same response.
By adding the line: WebServer.Enabled=True to the application .ini file fixes the problem.
Cheers
Phill
(2,847 Views)
