How do I control the time base of a graph programmatically?
If I'm displaying 4 cycles of a sine wave on a graph, how can I continue to display 4 cycles when the frequency changes?
(3,285 Views)
I'm not sure if this is what you are after or not.  But you can programmatically change the X-Axis of an XY graph using a property node shown below:
Message Edited by jmcbee on 03-13-2009 03:51 PM
(3,268 Views)
Thanks - this worked for me.  However, I  get a flickering effect on my waveform graph.  Any ideas how to fix?
Thanks in advance.
(3,243 Views)
Show us you code. 😉
Make sure to only write to the property when the frequency changes, and not with every iteration of the loop. What is your loop rate?
(3,240 Views)
Accepted by VI_Joe
Thanks for your help.  I solved my problem with an event structure. Smiley Happy
Do you know how to attach kudos and problem solved?
(3,220 Views)
To give Kudo's, click on the yellow Kudo's icon on the right hand side of your message.
To mark the question as solved, mark the green "Accepted Solution" icon on the right hand side of whichever message gave you the solution.  You seemed to have figured out the clicking of the Solved? Icon, but unfortunately, you clicked your own thank you reply rather than either Jim's or Altenbach's message.  (Whichever helped you more.)
If you go to the options menu to the  upper right of your last message, you can unmark your own reply as the solution.  Then you can go and mark the correct reply as the solution.
(3,205 Views)
