How do I convert a Variant of type=String to G data? (LV 5.1.1)
I've tried to return a string in the Variant return of a VB function in a DLL. (I want to do this so that I can retain the interface and thus binary compatibility in the DLL.)
When I use the DLL function in LabVIEW 5.1.1 I
get an error in the call library function call (returning). It looks like there is a way to handle this in v 6.0 but I have to use 5.1.1 for this application. Is there a way for LV 5.1.1 to handle a Variant containing a string?
Dave Karon
Concepts NREC
(2,913 Views)
Hi Dave,
you can use the type conversion function located under advanced -> data
manipulation to convert the variant into a string.
Henrik
Dave Karon schrieb in im Newsbeitrag:
506500000008000000C5260000-993342863000@exchange.ni.com...
> Thanks
> Dave Karon
> Concepts NREC
(2,913 Views)
It looks like my problem is in the return from the DLL.
It looks like the AX method node does not cope with a returned Variant of type=String.
Also, I do not see a type conversion function other than the "Type Cast" vi.
Is that a new function in version 6?
Dave
(2,913 Views)
