How do I convert the item name of an enum constant to text?
For an enum control or indicator I can use the "String[]" property together with Index Array to get the item text.
But for an enum constant, I don't know how to do it, however I have seen a solution some years ago, but I can't remember it.
Hoping that there is a skilled developer out there who is kind enough to help me.
(3,919 Views)
Hi Lefi
Haven't had time to really look at it, but there's always a way round things if you can't find an elegant solution.
Jevon
(3,914 Views)
Accepted by Lefi
Format Into String is your friend. You even don't need to set its format string input in this case.
(3,910 Views)
The OpenG Get Strings from Enum.vi can help, too.
Message Edited by jcarmody on 03-19-2010 06:42 AM
Jim
(3,886 Views)
Thank you JB for your compact solution. This is probably what I saw some years ago.
And thanks to jcarmody for the tip on snippets. I'll definetly try that.
(3,851 Views)
