How do I correct the X axis in a chart?
I am using Labview 7.1 to sample data. I wish to sample 120 seconds of data. I am using a chart and when I use a simulated signal, the VI works very well. When I connect the chart to the DAQ, the time axis no longer stays between 0 -120. I am using continuous sampling. Is there some way of displaying the data obtained while retaining a meaningful scale on the x axis?
Thanks!
(2,477 Views)
Hi. I had this problem too. Spent nearly a whole week trying to resolve it.
I was aquiring analogue data on multiple channels over multiple cards with synchronous clocks.
I eventually solved it by setting the chart max, min, and increment properties ia a property node. I could do this becuase I had to use finite samples in the aquisition. Max = max sample no., min=0, increment=dt
Hope this helps.
sampledout
(2,438 Views)
