Problem with Learn Correction Table - , of Learn Calibration of a Template
I'm working with Imaq of labview. I have several perspective images, and so, I need of Correction Table or Look Up Table.
So I have enabled, in the bloque "Learn Calibration of a Template" , Learn Correction Table,.Good.
But my simple questions are:
1.Does Labiew load automatically, the  Correction Table, in the bloque like Correction Calibrated Image?
and
2.If I do Learn Calibration of a Template, only to ROI; Does  Correction Table content the relaltions with full image?
thank you and sorry for my english.
(2,980 Views)
imaq Vision setup installs a calibration grid.pdf (Start>>Programs>>National Instruments>>Vision>>Documentation>>Calibration Grid.pdf) that can help you to calibrate your vision system following these step:
1. print the calibration grid
2. acquire the image of the calibration grid, this image will be your template.
3. acquire your feature
4. Use vision calibration functions to calibrate the feature image.
Following link is a tutorial that can help you with documents and examples:
Spatial Calibration
http://zone.ni.com/devzone/conceptd.nsf/webmain/ef66eeb671b0019b862569d10078c45e
Hope this help
Best Regards
AmbuA
(2,967 Views)
Thank you for previous post Ambua.
I have another question:
If Particle Analysis detects, or finds a particle, how to do  extract all point of this particle.
I need a vector, with all points of particle.
Thank you.
Matteo
Off Topic:
If I want to insert a image in this post, what do I do?
(2,957 Views)
