Troubles with examples opening
I have installed the LabVIEW 7.0. After that, when I’m opening the NI Example Finder by means of Help>Find Examples… , I see the massage window: “The NI ServiceLocator is not running. You will not be able to browse by Directory Structure”. And than it is impossible to open any example, and another message window has been appeared: An error occured – The NI HelpServer could not be found.” But ability to open these examples is very important for me.  How can I solve this problem? Please help.
(3,918 Views)
Alexander,
Check out this KnowledgeBase entry, it provides a solution for the ServiceLocator/HelpServer errors.  Hope this fixes it for you!
Sincerely,
RossC
(3,910 Views)
Thank you, it's very valuable help!
(3,892 Views)
No problem, I'm glad things are working better for you!
RossC
(3,886 Views)
