How do I count the number of 1's in a Boolean Array??
I have a boolean array of 1000 0's or 1's and want to know the number of times this array is in the 1 position.
The array is repeated within a structure and i need a number for each iteration to be passed onto the next (using a shift register).
Never really used boolean arrays before so none of the standard things i use seem to work?
Thanks in Advance.
Ross
(10,326 Views)
Ross,
The quick easy way is to convert the boolean array to a 0-1 array from the boolean menu, then sum the array using "sum array elements" from the numerical menu.
Bruce
Bruce Ammons
Ammons Engineering
(10,326 Views)
Ceers Bruce, works a treat.
Ross
(10,326 Views)
Cheers Bruce, works a treat.
Ross
(10,326 Views)
