In LabVIEW you can read jpg, bmp and png image file using the corresponding read picture function, which are located in:
Graphics & Sound -> Graphics Formats
Those VI's return the actual image as a 1D array (flattened image data) and a color table, which togheter will correspong to the RGB values you are looking for. You can convert the image array to a 2D array by using the "Unflatten Pixmap.vi", located in the same menu.
Use a numeric array indicator to display the color table values. Remeber that you should display these values as hexagesimal number to better understand them. To do that, right click an indicator in the array and select "Format & Precision...". Also, remember that a single value contain the RGB information, except if the image is 24-bit. In that c
ase, three consecutive numbers in the IMAGE DATA array represent a single pixel and the color table will be empty.
Best regards;
Enrique
www.vartortech.com
