How do I create a group of channels for input to a AI multi point
    How do I create a group of channels for input to a AI multi point, so that I can output it to 3 different graphs.I figured out the graphs but I am not able to figure out how to create the group of channels for the input.I saw many examples where a group of channels is given as an input.
(2,828 Views)
check the vi which i have attached. i am not sure about your requirement. what i understood i made a vi for that.
(2,827 Views)
Hi Binoy,
       Thanks for your reply.Unfortunately I am using Labview 7.0 and it wouldnt open 7.1 version files.Could you please tell me how do you create a group of channels say 4,5,6.This group of channels must be given as an input to the AI multi pt.I know how to given one channel as an input but I dont know how to give a group of channels as an input.
(2,826 Views)
hello
You have to put Daq Mx Create virtual channel.vi in a For loop. out side that u should give an array of virtual channel which ever you need to acquire. i am sending the vi in 7.0 too.
(2,821 Views)
Hi Binoy,
Thanks a lot man...Thanks for the quick reply
(2,815 Views)
