How do I create labview program for Mass flow controller
Hie,
     I have to create a VI for Digital mass flow controller type MF1 from MKS, It has an mini USB setup interface and USB 2.0 Process interface there is  a command list which can be sent and we get a feedback of the same ,
it should
•Calibrated to N2
•Apply gas correction factors
•Selectable gases: Ar, N2
•Assignable class: carrier gas, purge gas, reactant gas
I am not new to labview but I have no clue hw do I start with the programming which should also include gass correction factor could you please show me some example VI which I could refer too.
here is the attach instruction manual of the MFC
Message 1 of 20
(11,348 Views)
Hi Patel89,
You will have to communicate with the device as a USB RAW device. Check out the tutorial listed here: http://www.ni.com/white-paper/4478/en/
Please note that you will be creating the VISA driver using the NI-VISA Driver Wizard.
Kind regards,
Rick Wagner
Message 2 of 20
(11,295 Views)
Actually, the manual says the device can appear as a normal serial interface so using the VISA wizard and USB RAW would be a huge mistake.
Message 3 of 20
(11,278 Views)
True enough ...
Message 4 of 20
(11,272 Views)
Yep ...
Message 5 of 20
(11,270 Views)
Hi patel89,
as a start up for using VISA for serial communication, I would suggest you to have a look on this introduction/tutorial:
http://www.ni.com/support/visa/vintro.pdf
Moreover, in http://www.ni.com/support/visa/  you will find other resources such as LV examples and reading materials.
Best regards
Anoj Mubarak
Message 6 of 20
(11,249 Views)
I found this VI library. It is not for your device and it was from LabVIEW 5. However, I updated to LabVIEW 2013 and posted it. It should at least give you and example of this type of communication. The website I got it from attributes it to Thomas Roth. Hope it helps ...
Kind regards,
Rick Wagner
Message 7 of 20
(11,216 Views)
so I should use  USB INSTR Class (USBTMC)  which uses read and write instruction to communicate with my device
Message 8 of 20
(11,156 Views)
No, it's not USBTMC. Look at how the device is enumerated. The manual says it should be a serial device.
Message 9 of 20
(11,141 Views)
Many instrument manufacturers are using chip sets that "convert" USB to a RS-232 serial port. One of the chip makers is FTDI. They provide a driver that shows up in the operating system (and MAX) as a serial port. However, if your device is not showing up as a serial port it may be because of a problem assigning the port number. Please look at the attached application note from Digalog Systems.
Message 10 of 20
(11,089 Views)
