How to control MFCs with ADAM 4000 modules through labVIEW
Hello all,
I want to control 2 MFCs from Brooks using ADAM 4000 modules through labVIEW. I use labVIEW 2021 in Windows 11. The ADAM modules I have are 4561, 4017 and 4024. Although I see the assigned COM with NI VISA, I still can not figure out how to find out the addresses of the ADAM modules and consequently how to control the MFC. I see that a Modbus library is needed but I can not find one compatible with Win 11. Also, I tried using some commands through NI VISA but still did not have any luck as well as some trials that were done with the Simple Serial.vi. Could you help me how to define the ADAM modules addresses needed?
Thank you in advance!
Ioannis
Message 1 of 1
(633 Views)
