How do I determine if a file exists or not on my PC?
I thought this would be an easy one and maybe I am just making it harder than what it has to be. I simply want to search in a given directory to see if a file exists on not on my hard drive. Are there any ideas as to how to do this without causing an error if the file does not exist?
(3,976 Views)
Hi:
In those situations what I've done till now is opening  the file and  close it inmediatly, if I find out and error while opening it I guess it doesn't exist. I know this is not the best way since there may be other reasons for the Open File Function to fail, but it has worked for me. Does somebody know a better way to do it?
Regards
Robst - CLD
Using LabVIEW since version 7.0
(3,965 Views)
You can check the error output of the File/Directory Info function, and if there was no error, the file does exist.  This method will not work if you're checking a path inside an LLB.  In that case, you would have to do something else, like listing the parent LLB contents and seeing if the file exists inside that parent.
I plan on including a new VI on the Advanced File I/O palette in the next version of LabVIEW that, given a file path, will return a boolean indicating if that file/folder exists...it will also work on files inside LLBs.
Hope this helps,
-D
(3,960 Views)
The error method is easiest.  But if you can't live with producing an error, you can use the List Directory function (File I/O - Advanced File Functions).  This will output a list of files and directories in a string array format.  You can then search the array for the filename.
- tbob
Inventor of the WORM Global
(3,940 Views)
Alternate method:
If you know the path where you want to check the existence of the file, use the "build path" and then use "File/Directory info", and then check the error status. This will work if you know the path where you want to check.
Kudos are the best way to say thanks 🙂
(3,912 Views)
