How do I determine the executable version number?
Hi.
I have a VI and a build specification for it.  In the Version Information section of the build specification, I set the version number to auto-increment.  I would like to display this version number on an indicator on the front panel of the executable, but I have not found a property that provides this information. Does anybody know how to get the executable version number? I am aware that it is possible to right-click on the .exe file in windows explorer, go to properties and get it that way, but I would like to display it on the VI itself.
On a related topic, I have noticed that only the 'build' field of the version gets auto-incremented. How does the application builder decide when it is time to increment the major, minor and fix fields?  Or will it only ever auto-increment the build field and I am supposed to update the other fields manually? (That would actually make sense, but I would like confirmation.)
Thanks in advance,
Alejandro
(6,729 Views)
Accepted by AlejandroZepeda
(6,719 Views)
I usually keep tis AE in my reuse library.
(6,706 Views)
Funny-  I thought that would post snippette-wise (Funny doings with the firewall here)  Updated to silver
(6,675 Views)
Hi.
Thanks for your responses.  I ended up doing a hybrid of the 2 solutions offered and got it working.  I am surprised that this is so hard to do.
Alejandro
(6,630 Views)
Unfortunately some of the property nodes/invoke nodes do not exist in Linux version of LabVIEW.
(6,305 Views)
I just posted what should be a workable solution for Linux on a similar question.  See if this solution works for you.  [I'm not sure how to paste a link to it, but this is what shows on the Address Bar when I view my earlier post ...]
http://forums.ni.com/t5/LabVIEW/Determining-the-version-of-an-executable-under-Linux/td-p/957378
(6,280 Views)
