Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How do I determine the portion of a curve that has the greatest change in slope?
Ladera
Member
06-03-2005
02:48 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am acquiring a dc voltage that shows more than one variation in slope.
I would like to know the portion of that curve that has the greatest change in slope
0
Kudos
Message
1
of 3
(2,776 Views)
Reply
Re: How do I determine the portion of a curve that has the greatest change in slope?
Dr._Imad
Active Participant
06-03-2005
03:25 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The derivitive at a point of a curve is the slope at that point.
There is a function under
Analyze---signal processing-----time domain---Derivitive x(t).vi
Just Pass the waveform data to the vi and search the slope for maximum.
0
Kudos
Message
2
of 3
(2,768 Views)
Reply
altenbach
Knight of NI
06-03-2005
05:20 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Also remember that if your signal has significant noise, you would need to do some filtering or you'll only measure the very steep "slopes" between successive points. Probably not what you want.
LabVIEW Champion
0
Kudos
Message
3
of 3
(2,755 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
