How do I disable the Oscilloscope keyboard lock when running a program
I have created the piece of code required to change the timebase and time delay settings on the oscilloscope and then convert the waveform to a spreadsheet file. However, because the code is in a while loop, the settings keep getting updating, thus throwing everything off.
Is there any way I can change the settings on the DSO1024 Oscilloscope manually and then use the code to take the measurement?
(3,654 Views)
Hi Kghangas,
You could change your code to do those settings just once, before the loop…
Does the scope understand commands to en-/disable the keyboard like most other (better) devices? Use them!
(3,649 Views)
I have a DSO1024 oscilloscope and I could't acquire the channels waveform's in LabVIEW via USB connection. Could you please help me with that?
(3,000 Views)
That has nothing to do with this topic.  Start a new thread, preferably in the Instrument Control board.
GCentral
(2,997 Views)
