How do I display 2 VI non-modal dialogs that require new input values
I have a VI that, at a specific point, should display 2 more VI dialogs in a non-modal manner. These VI's have required terminals and I want to feed values from my parent VI into those terminals. Then I want those VI's to run in a non-modal manner and allow the parent VI continue it's processing.
The user will then close those dialog VI's at an appropriate time?
I can use FP.Open to open the VI's, but how do I set the terminals without causing modal behavior that causes the parent VI to wait until the "children" are "finished"?
Thanks!
David
PS: Actually it's 5 non-modal dialogs, but I wanted to keep the question simple; any solution should easily scale to significant numbers like 5 or 10.
(2,537 Views)
To others: this is a repost of this message that somehow ended up in the BreakPoint forum.
To OP: Use the Control Value:Set [Flattened] or Control Value:Set [Variant] method to set the control values before running the VI.
(2,527 Views)
