modbus
HI ALL
Im using an universal controller NOVUS N1100 and im trying to communicate with LabVIEW 8.0. The protocol is MODBUS RTU. My problem is how can i communicate that controller with Labview 8.0, i downloaded the MODBUS library, but i see in a demo i can use shared variables and just connect, all in a new project, but when i try to do the same cant find the modbus server option, i need install something???
Thanks for all
(4,656 Views)
I guess this was a demo of the LabVIEW DSC module...
(4,639 Views)
Accepted by topic author Mr Bungle
Hi Mr Bungle, as JB mentions probably what you saw is a demo of LabVIEW DSC. LabVIEW DSC is an additional Module that allows to connect to PLC and adds additional functionality to LabVIEW to create more complex SCADA systems.
To work with Modbus from LabVIEW you can use the free library or the Modbus I/O Server that is included in either LabVIEW DSC or LabVIEW RT.
You can download a 30 day trial for this modules for LabVIEW 8.6 (you will also need to download it in evaluation to test this functionality).
https://lumen.ni.com/nicif/us/evaltlktcds/content.xhtml
 Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(4,613 Views)
