How do I extract columns from an array?
I have an array with three rows and a variable number of columns. Is there a VI or some other method that I can use to extract certain columns from the array based on the column indices?
(4,102 Views)
The Index Array function does just that with the index disabled on the row index and an integer wired to the column index.
Here's a link to a handy example:
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3EFED56A4E034080020E74861&p_node=DZ52026&p_submitted=N&p_rank=&p_answer=&p_source=External
2006 Ultimate LabVIEW G-eek.
(4,102 Views)
Thanks, that is what I was looking for.
(4,102 Views)
