can RF signals be used with ni pxi-7831R card
what is the frequency range of signals that can be analyse with FPGA 7831 card
(2,727 Views)
The analog input can acquire signals at 200 kHz. The digital inputs can acquire signals in one clock cycle of the FPGA, so the actual acquisition speed for digital depends on your specific application code, but can be as fast as 40 MHz. Processing of data also depends on the amount of code in your processing routine.
As an alternative to the onboard analog inputs, it is possible to use a faster external A/D converter and use the high speed digital interface to read the data from the external ADC.
Christian L
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(2,727 Views)
