How do I find the average waveform?
Hello Fellow Engineers!
I need some help from you. I am trying to program an application which is as follows-
I collect a signal waveform from a sensor. This waveform changes its characteristic shape mildly over each period due to disturbances and so on. I need to find the average waveform over N (say 3) periods. So, the slight changes in the characteristic shape over each period must be averaged out and I must have a resulting waveform, which reperesents the average waveform over a period. Could any of you suggest a way of doing this?
I await your creative ideas and suggestions,
With warm regards,
Aparna.
(3,177 Views)
Hi NI_user_s...,
store your waveforms in a shift register. After you have all your waveforms from which you want the average, start a new loop and calculate the average over all.
Mike
(3,165 Views)
You have not indicated whether you're collecting the waveform multiple times over a single period, or whether you're collecting a single waveform over a time frame that is multiple periods.
(3,162 Views)
