copy file
Hi all
i want to copy file from one place to another ,,
for example copy file from specific path to another
how can i do that
thanks alot
(3,401 Views)
Hi elyan,
you can use the "copy" function -> this is the easy way, or you open the file, create a new one and copy it byte per byte from the old to the new file. If you use the second way you can show an information to the user.
Hope it helps.
Mike
(3,398 Views)
Hi :
i slove it but how can i change his name "rename " the file
thanks
(3,392 Views)
Have you tried actually looking at the LabVIEW User Manual? The Move function does this.
(3,389 Views)
Simply give it a new name in the destination path.
RayR
(3,384 Views)
Thanks alot
I Solved it
(3,378 Views)
