How do I get the VISA resource drop down menu to be auto populated in my stand alone application (exe file)?
Hi all,
Here's a hopefully simple question.
I am building an application (i.e. an exe file) from a simple program which use VISA to read and write to a RS-232 com port. When I run it before building the application everything works fine and the VISA resource control, which is a drop down menu, is automatically populated with available com ports. When I run the application on a computer without LabVIEW installed nothing appears in this window. I have made an installer which includes NI LabVIEW Rutime Engine 8.5, NI Measurement & Automation Explorer 4.3 and NI-DAQmx 8.6.1. Is there anything else I need to include? Any specific settings I need to do when I build the exe-file?
I use LabVIEW 8.5.
Thank you.
(2,837 Views)
Accepted by cmh
DAQmx is only for NI DAQ cards so I'm not sure why you installed that. The driver for VISA applications is NI-VISA (surprise!)
Add the NI-VISA run-time to your installer.
(2,828 Views)
