How do I get the binary data file from the "High Speed Data Logger.VI" into an Excel spreadsheet? I don't want it in binary form- I want it converted to ASCII or some readable form.
I am using Labview 6.1. ActiveX isn't working on the computer I'm using so I can't use that method. Also, do I have to account for the header text at the top?
I have seen a few posts somewhat related to this topic but they have either not helped, or I don't understand the answers given. (So please don't link to another if you don't mind). Thanks for your time!!!
(3,174 Views)
take a look at the high speed data reader.vi... you shoul dbe able to adapt that to do what you want...
Dan
(3,174 Views)
I took the High Speed Data Reader.VI and added the Write to SpreadSheet.VI. Shouldn't that be able to write the converted data to file? What am I overlooking here. I am attaching a screenshot!
THANK YOU.
(3,174 Views)
That should work. Please explain what the problem is. Is the file empty, formatted wrong, or what? Kind of hard to help when you don't say what's broken.
(3,174 Views)
Watch out with Excel. As you use the High Speed Recorder to create the
original file you will most probably create quite large files quite
fast. Translating that into an ASCII spreadsheet would work fine in
LabVIEW but Excel has a limitation that it can't open spreadsheet files
above a certain number of rows. I do believe this is around 64k rows but
it does a little vary depending on the number of columns you have.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,174 Views)
If you need to you can download a trial version of Quatro Pro. It will
take over a million rows.
Doug
> Rolf Kalbermatter
(3,174 Views)
