How do I get the speed (RPM) from the Encoder VI
Greetings,
I have a two motors with quadrature encoders attached to them.
I am using the Encoder VI with the myRIO, which outputs two values - Counter value and Counter direction. From the counter value I am trying to display the speed (RPM). All the counter value does is is count up or down depending on the direction; I need a way to use these counts to measure the speed. I can't figure out how to do this?
Thank you in advance for your help.
Message 1 of 10
(10,376 Views)
You should count difference in counter values and divide it to period of measuring.
Message 2 of 10
(10,363 Views)
Accepted by topic author stanm13
Not exactly, the result of the count substraction need to be divided by the number of encoder counts/rotation before being divided by dt (expressed in minutes).
Ben64
Message 3 of 10
(10,339 Views)
// Not exactly, the result of the count substraction need to be divided by the number of encoder counts/rotation before being divided by dt (expressed in minutes).
  This is true. But I hope  stanm13 understands it 🙂
Message 4 of 10
(10,328 Views)
Thank you very much. I understand now.
Message 5 of 10
(10,319 Views)
Hi ,
You have used subtraction , division blocks . Can you tell me the name of that other block in the image?
Thank you !!!
Message 6 of 10
(9,332 Views)
"feedback node", it's the same as shift register in loops
Message 7 of 10
(9,329 Views)
Thank you!!!
If I put those feedback node in a while loop , what should be the value of " dt " ??
Message 8 of 10
(9,294 Views)
The time between reading or time between counter increase
Message 9 of 10
(9,258 Views)
I found the execution time for while loop in another post . Can I use this output as 'dt'?
Thank you!!
Message 10 of 10
(9,250 Views)
