How do I get the standard LabView startup screen back after installing the robotics evaluation module?
I installed the Labview Robotics module for evaluation, but when I now start Labview I am meet with the following startup screen:
How do I get the standard Labview startup screen back?
(3,585 Views)
My understanding is that the startup screen will revert to the original after the evaluation period is over.
I think you can also uninstall the robotics module, and it will restore the original startup screen.
Brian
(3,575 Views)
Accepted by Terje
Terje,
When LabVIEW Robotics is installed it overwrites the LabVIEW Getting Started Window file.  You can get back to the standard Getting Started Window by repairing the LabVIEW install:
  1. Navigate to Add/Remove Programs from the Windows Control Panel.
  2. Click National Instruments and select Change/Remove.
  3. Choose to repair LabVIEW.
  4. Insert the LabVIEW installation disk if you have one or navigate to the network location that you used to install LabVIEW.
  5. After you have repaired LabVIEW, you should be able to restart it with the default Getting Started Window restored.
Chris M
(3,542 Views)
how about the opposite to this question?  i just upgraded to LV2009 SP1, and I want my LV Robotics startup screen back.
(3,232 Views)
