How do I get the vi to wait for the user to select a COM port?
This is a problem when I run the application.  If the COM port selected is not the one actually connected to the hardware then I get an error.  I can then select the correct COM port, re-run the application and everything is fine.  But I want the application to run when called by the user and wait until the correct COM port is chosen.  I will settle for the selection of any COM port and put the responsibility for proper selection on the user.  Thanks to all.
Message 1 of 12
(4,057 Views)
Hi Havelld,
you can use an event structure to wait for the selection.
Mike
Message 2 of 12
(4,051 Views)
Had the same problem. I used to select the highest com port number available. When I ported the hardware the com port number used to get incremented.
You can use a while loop like this
Message 3 of 12
(4,043 Views)
Hi muks,
how should someone change/select the com port if you use a constant in a running vi?
Mike
Message 4 of 12
(4,040 Views)
Mike,
It is just to show the com port number which has gone to 23 in the picture. Obviously one has to change it to a control.
Message 5 of 12
(4,036 Views)
Okay, that makes sense.  I'll try that.  Thank you for your time.
Message 6 of 12
(4,011 Views)
Mike,
Yes, I have tried that but I am afraid I don't understand event structures well enought to make it work.  Maybe I wasn't properly placing the event structure; i'm not sure if it should be a separate loop or somehow incorporated in, or around, the main loop.
Do you have a good example or tutorial I can start with?
Message 7 of 12
(4,013 Views)
Hi Havelld,
the attached picture shows the simplest solution. If you already use an event structure in your vi, then you should integrate this function into the existing structure. I don't recommend to use more than one event structure per vi.
Mike
Message 8 of 12
(4,008 Views)
Accepted by topic author Havelld
Of course.  It's working great now.  Thanks MikeS81!
Message 9 of 12
(3,996 Views)
Hello all,
is it possible to have your file in Labview8.0, please ?
Message 10 of 12
(3,969 Views)
