07-20-2009 08:04 AM
Is it possible to send a notifier from a workstation to a RT target (8145 RT)?
I am trying to construct a SW trigger for a DAQmx Task that I only want to execute when the workstation tells it to. The Shared variable engine does not support the notifier class (?) so I wasn't sure how to accomplish this (if possible).
Adam
07-20-2009 08:11 AM
Hi Adam,
no, you can't send a "notifier". You can send a command with a shared variable or with the tcp/ip function to your rt target. If you receive this command on your rt device, then you can send the notifier from there.
Mike
07-20-2009 08:51 AM - edited 07-20-2009 08:55 AM
What about using an Occurence?
If I make shared Occurence Refnum control, can I can use the workstation VI to Set Occurence and the RT VI to Wait for Occurence.
Thoughts?
07-20-2009 08:55 AM
No,
all elements on the synchronization palette are station specific and cannot be shared in network.
Mike already suggested the way to go: send a command from your host to the RT via TCP or other network capable protocol.
Maybe you want to know about STM.
hope this helps,
Norbert
07-20-2009 09:00 AM
Hi MREDAY,
i think this also don't work. You need something which work with tcp/ip, either shared variales or the tcp/ip functions. I can't see a occurance type for a shared variable. I would send the trigger with tcp/ip functions.
Mike
