How do I install LabVIEW 6.0 over the evaluation version? I can't un-install the evaluation version.
I get the message that another version of LabVIEW 6.0 is already installed and it won't let me install 6.0. How do I get rid of the evaluation version?
(2,932 Views)
Do you get an error when you try to un-install the eval version? I am able
to successfully remove it, via Add/Remove Programs in Control Panel.
Jeff
"Raytheon Ron" wrote in message
news:5065000000080000008C1E0000-986697009000@quiq.com...
> evaluation version?
(2,932 Views)
I don't have LabVIEW in my Add/Remove Programs. I may have at one time, but
can't remember. The removal must have been incomplete becasue LabVIEW 6.0
says "Another version of this produce is already installed." The same thing
happens if I try to reinstall the evaluation version.
Ron
JeffD wrote in message
news:AJSO6.29900$TW.143215@tor-nn1.netcom.ca...
> Jeff
> > I get
> > evaluation version?
(2,932 Views)
If LabVIEW is not in the Add/Remove programs, then you can just delete the entire directory where it resides. The default directory is Program Files\National Instruments\LabVIEW 6. Just nuke that puppy.
(2,932 Views)
