How do I integrate Phantom device into LabView?
I want to create an interface in Labview that has visual, auditory and haptic modalities. I have a Phantom Haptic Controller and I need some advice on how to integrate these into LabView.
I have a Simulink simulation code that I was using with the Phantom before, however, I am trying to re-create this in Labview. Does anyone have any experience dealing with haptics and LabView? Thanks for any help!
(4,186 Views)
What type of controller it is?.. what is the inetrface that the phantom device uses?...
Smiley Wink
(4,163 Views)
How you are you re-creating this in LabVIEW.  Are you using the Control Design and Simulation for your modeling?  If you have a model already built you should take a look at this article
Hope this helps.
Justin Parker
Product Support Engineer
(4,136 Views)
