DAQ Assistant & Error correction task
Hello!
I have to correct errors in this temperature measuring task. I was sitting all day long on it and couldn't find useful information in internet. Could someone help me solve this?
(4,764 Views)
Start with the basic LabVIEW tutorial.
Don't you realize that you've connected that split signal to the error out - not the data? And connecting the Boolean to the wait function is also pretty obviously wrong.
(4,759 Views)
Well, I made some changes but it still doesn't work. I think I have connected the split signal wrong..
(4,745 Views)
Explain 'it still doesn't work'. Attach the actual VI. Can't debug a picture (unless it's a snippet).
(4,742 Views)
this is my VI
(4,733 Views)
You still have not explained "it still doesn't work".
The only thing I can see is that since you are only taking a single sample from each channel, doing a mean of each value read seems pretty silly.
(4,711 Views)
actually, maybe I am taking this too seriously. my teacher just gave me this example (attached) and said that I must correct errors of this VI. I am not sure, whether this instrument has to do anything that makes sense.
(4,702 Views)
