How do I load a picture from the clipboard (either Windows clipboard or Labview clipboard) into image data that can then be processed in Labview?
This thread contains two different topics, both five years old.
You probably need to be much more specific what your problem is and what solution you are looking for. Maybe start a new thread entirely.
Message 11 of 12
(706 Views)
Hello altenbach,
thank you for reply!
Yes, you are right Smiley Happy
My task is to get an image from clipboard.
I use the invoke method “Clipboard.Get Image” which is discussed in the thread.
The Problem is that it works fine as LabVIEW-SorceCode.
But as soon as I run it as a compiled exe, it no longer works.
Then just strings are able to get as an image from clipboard0, but not longer screenshots (for example).
Flobias
Message 12 of 12
(695 Views)
