How do I make a particular row to blink in a multicolumn listbox?
I am updating different parameters in a multicolumn listbox. I need to make an entire row in the listbox to blink when one of the logged parameter goes beyond the limit so that the user will come to know the fault. I have provided an Acknowledge button in UI, which when pressed makes the blinking off.
The blinking property in the LabVIEW makes the entire listbox to blink. I can't able to make a particular row of the multicolumn listbox to blink. How can I do it?
I have attached the picture of my User Interface (UI.jpg)
Kindly help me regarding this.
Ramkumar.D
QuEST, INDIA.
(2,962 Views)
I attached one way of doing this. Don't forget to set BG color white after acknowledging.
Hope this helps
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,958 Views)
Thanks Thomas, I got the idea. I will use in my application.
Ramkumar.D
QuEST, INDIA.
(2,952 Views)
