How do I make sub vi's front panels visible
I haven;t used in Labview in a while and I can't remember how I make a sub vi's front panel appear when I call it from the main VI. any help is a appreciated.
I am using labview 5.1
(3,429 Views)
In LabVIEW 6i, this can be done by accessing the SubVI Node Setup dialog box. Right-click a subVI on the block diagram, then select SubVI Node Setup from the shortcut menu.    Select "Show Front Panel When Called" in the SubVI Node Setup dialog box. Appearance of the subvi will be according to option in its VI Properties.
(3,429 Views)
On the front panel, right click on the sub-vi icon in the upper right,
click on VI setup. Should be a box there for "Show front panel when
loaded" and "Show front panel when called". Enabling one of these will
cause your sub-vi's fromt panel to be displayed when running.
>is a appreciated.
48k and I need a cable modem badly!!!!!
(3,429 Views)
