Time delay
I am trying to make a variable time delay as part of a much
larger system. I need
y(k)=u(k-d)
where d is a control integer variable,u is the input and y is the
output.
I tried putting a WHILE loop within a FOR loop but have problems.
Any suggestions?
regards
Tom
(3,138 Views)
Check timed while loop to see if it can be modified to suit your purpose.
(3,138 Views)
Many thanks but I figured out a way that works.
What I do is convolve the array to be delayed (by any variable delay)
by another array [1 0 0 0 0 0 0 0] where this is changed to [0 1 0 0 0 0 0 0]
for 2 step delay [0 0 1 0 0 0 0 0] and so on!
regards
Tom
Aderogba wrote:
> Check
> href="http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/00464228e2cf35ce862...
(3,138 Views)
